nsight-policy (global-config-mode)
Creates an NSight policy and enters its
configuration mode. The NSight policy configures parameters that enable controllers or virtual
controllers (VCs) and RF Domain managers to post periodic-stats, event logs, and configuration
information (such as RF Domains, location hierarchy, WLANs, device inventory) to a designated
server host. The server could be an NSight server deployed on an external VM appliance or the ExtremeCloud IQ
server.Any WiNG controller that is onboarded to XIQ can be managed from XIQ. You can
use the SSH proxy option on XIQ to open SSH connection with WiNG controller for accessing
the CLI and web proxy option to launch the GUI. This feature is also supported on WiNG
access points configured in virtual controller mode.
You can use your existing
credentials to access WiNG CLI or GUI.
ExtremeCloud IQ server support
has been introduced in the WiNG 7.3.0.2 and WiNG 7.3.1 firmware. Going forward, WiNG
devices running on the aforementioned firmware (or successive versions) can securely
connect to the ExtremeCloud IQ server.
After configuring the NSight policy
apply the policy in the following contexts:
- RF Domain - The RF Domain manager posts
periodic-stats (polled from APs within the RF Domain) and changes in operational
parameters of APs within the RF Domain to the server host configured in the NSight
policy.
- WiNG controller or VC (self or profile)
- The controller or VC posts event logs and configuration information, such as RF
Domains, location hierarchy, WLANs, device inventory to the server host configured in
the NSight policy.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
nsight-policy <NSIGHT-POLICY-NAME>
Parameters
| <NSIGHT-POLICY-NAME> |
Specify the NSight policy name. If a policy with the specified name does not
exist, it is created. |
nx9500-6C8809(config)#nsight-policy test
nx9500-6C8809(config-nsight-policy-test)#?
Nsight Policy Mode commands:
enable Enable this Nsight policy
mandatory Configure mandatory app stats reporting
no Negate a command or set its defaults
server Configure Nsight server
clrscr Clears the display screen
commit Commit all changes made in this session
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
| no |
Removes an existing NSight policy |
